I will definitely check into this weekend and see if I can narrow it down. Thanks so much for the advise.Seeing the car turns over, have you checked for spark while cranking? Maybe, just maybe your key switch is not sending power to the coil. I am a very rusty but I thought on many cars when you turn key to start, a wire carried power to coil. Once car starts and you release the key a different wire completes the circuit.
The Instructions I found online says it can produce full voltage with 9-18v. Is there a resistor wire in you ignition (coil, 6al) circuit? These items need full voltage. No resistor wire is used.With the key on I have 12.75 volts but in the start position its 8.5 volts. Not sure if this is enough voltage to kick the 6al box in?
No resistor wire except the one from the alternator and its a diode feeding back to the battery.The Instructions I found online says it can produce full voltage with 9-18v. Is there a resistor wire in you ignition (coil, 6al) circuit? These items need full voltage. No resistor wire is used.
Yes, but the spark is orange and not white or blue so I am assuming this could be my battery if I am only getting 8.5 volts at the start mode.If your looking at the mad, I am guessing you did the simple spark check at the plug wire?
Are you measuring the voltage on the starting circuit of the ignition switch or the battery? It could be your battery, testing at the battery itself while cranking will tell you that. If on the starting circuit, you may have a degraded contact on the ignition switch.Yes, but the spark is orange and not white or blue so I am assuming this could be my battery if I am only getting 8.5 volts at the start mode.
Are you checking voltage “at” the battery during cranking? That’s where you’ll know if the battery is weak or bad. Put your leads on the battery and have someone crank it. You can make longer leads with wire if you are working alone.Yes, at the ignition switch and had 8.5 volts there. After reading more on the 6al box , they are recommending 10volts at the state mode. I will pickup a new battery this weekend so I am praying that this is the culprit.
When you say "negative" I'm wondering if the gauge is an ammeter or a voltmeter. Not that it really matters t-shooting your problem, but it would be nice to know what you have there.When I try to start the car my volt gauge goes as far negative as possible.
Ok. When I'll check to be sure tonight. ThanksAre you checking voltage “at” the battery during cranking? That’s where you’ll know if the battery is weak or bad. Put your leads on the battery and have someone crank it. You can make longer leads with wire if you are working alone.
