I've been doing a lot of searches on here and researching quite a bit on here. Great forum you guys have! Very helpful articles & posts, more helpful than any other site I could find on the internet.
Only problem is, I don't plan on spending much money to paint my car and I'm only looking for an OEM-quality finish. I have a 1993 Ford Festiva that has no rust, and still has factory paint. I've painted my Mazda MX-3 in the past and it turned out pretty bad. I went from a bright red to a slightly darker grey metallic color and I had lack of coverage, only minor runs here and there (my own fault) and A LOT of orange peel on the clear coat.
I have a few questions. I guess i'll just list them instead of ramble on.
First here is my setup:
Coleman 6hp 21 gallon tank: 7.7 CFM @ 40psi, 6.0 CFM @ 90psi
Ignersoll-Rand 33. oz HVLP top-feed gun w/1.5mm tip, 43 max psi and Avg air consumption of 8.2 CFM.
Companion (generic sears brand) DA sander w/6" pad
I plan to use sherwin-williams urethane single stage Western Dimension paint & clearcoat. I'm using overall clearcoat w/overall hardener (4-1 mix ratio) and their Dimension paint (2-1 ratio w/reducer).
Here are my questions:
1): Any problem with the paint I'm using? Its like $20-30 a qt for the paint & $20 for a qt of clear. I know its cheap stuff, but I don't want to spend hundreds on paint alone.
2): Since the car only has the factory coat of paint, can't I just scuff up the paint and paint over that? I don't see the need to strip it to bare metal & primer it unless I'm going for a flawless job.
3): If scuffing up the paint is ok, what grit do you recommend using? I used 320 and 400 (mixed 6" discs) when I did my Mazda a year ago.
4): After scuffing up the paint, do I need to use any kind of prep wash? When I did my mazda, I just used a dry cloth to get rid of the paintdust & used a tack cloth to get the rest off.
5): Is my compressor / HVLP gun setup bad? I know I should use a compressor that puts out at least 8.2 CFM at 40psi but those cost over twice as much as my compressor/tank setup costs. Should I just let it charge up when the air gets low and stop painting? or should I be OK using it as is?
6): I read the FAQ's regarding painting and in the FAQ #4 tips for setting the spray nozzle are mentioned. I fear this was the main problem with my horrible orange peel & runs when painting my Mazda. Problem is, my gun has three different controls you can set, the fluid control valve (which is what that FAQ talks about setting), the spray-pattern adjuster and the air adjustment valve. How should I set my spray adjustment valve? How big of an area should that "cigar shape" be from 8" away?
7): Which way should I set my nozzle? So the pattern is horizontal or vertical? I'd think vertical is best since it is easier to see, but do you guys have any recommendations?
8): When spraying, exactly how far away should the gun be from the surface? I've read a bunch of stuff like 6", 8" even 12".
9): When spraying a metallic paint. Do you recommend using numerous light coats, or 2-3 medium coats?
10): Any tips on how to heat up a garage during the winter without risk of blowing yourself up? I have a kerosene heater that has an open afteburner-style flame. I have a basement with a door leading to my 2-car garage. I was thinking of setting the heater up in the basement, and having a fan blow into the garage the hot air to help heat up the garage to a decent temperature. Is this a recipe for disaster? When I painted my car before, I could barely smell anything once I was done and removed my respirator (it was also a urethane paint btw).
Please help this poor festiva before I ruin it!!
http://projectmazda.com/festiva/mycar/julyfront.jpg
Thanks in advance.
Thanks in advance.
