Hello guys I have a question here and need some ideas. First of all I don't have access to a welder so that is out of the question and funds are tight at the moment and I have a Holley 600 vacuum secondary and the base plate is still in excellent condition and the throttle shafts are nice and tight and overall has little wear on it but the problem is the gold side bracket that your throttle cable hooks up to and your return spring hooks up to is loose and I don't know how to fix that without having to buy a new throttle shaft and install a new one in which is not a problem as I have done many of those before.
Is there a way to fix this without welding it like some folks do? I have heard that some people try to peen it again but I hate to say I am green in that area when it comes to doing things like that and don't want to damage things further. I tried to bend it a hair as it was slightly bent but it was still loose. It does not wobble real bad but enough it can eventually wear out the shaft bore with it being floppy like that and I feel create a out of round bore even further in the throttle shaft over time.
Is there a easy way without welding to fix this? Any suggestions would be appreciated. I know they stake it at the factory on the side and peen it over to press on it. From what I can tell it makes contact but would not know how to do this without making it worse. Thanks guys to any who may help
