We're about to head out of town tomorrow for a spring break trip. I changed the oil yesterday and today we started getting low oil pressure indicator when sitting at a stop light in drive. I think it is an electrical problem but wanted to run it by you guys before heading out.
2012 F-150, 5.0 L V8
150,000 miles
It's got the dummy gauge that pretends to say what the pressure is between L to H
- Intermittently (maybe half the time) the oil pressure drops to L and the car dings when sitting at a stop light in park with Idle at 500 RPM. Only does it when warm.
- I swapped the oil pressure sensor/switch for a new one. Problem persisted.
- I let the car sit for 1 hour and checked the dip stick 3 times. Oil level is right at the top of the hashmarks so it's got the right amount of oil.
- I bought a new mechanical oil pressure gauge and connected it up to the hole that the sensor was in. It read 28 lbs at 500 RPM idle with the truck in drive. Went up to 80 lbs when my wife revved it in park.
- I connected the new sensor to an air pressure regulator on shop air. I slowly increased the pressure from zero and measured the resistance/continuity through the sensor. It is a one wire sensor that connects to ground when there is enough pressure. This one connected to ground at 5 PSI. So it would seem this sensor for the dummy gauge will say "good oil pressure" with anything above 5 PSI.
- So I've got a sensor that will show "good oil pressure" with as little as 5 PSI. And my mechanical gauge shows 28 PSI at 500 RPM.
- There is an oil leak somewhere above that has the whole wire and connector drenched in oil. But I checked the resistance between the connector and about 3 inches up the wire from it (stabbed probe into wire) and got 0.3 ohms so the connector resistance seems fine.
- I was NOT able to read the oil pressure with my mechanical gauge and see the dummy light show "no oil pressure" at the same time. I didn't have the fittings I'd need to hook that up. So I can't 100% positively say that I've observed good oil pressure at the same time the dummy light was going off. The car did sit for a good 30 minutes before testing with the mechanical gauge. And before I had to drive it for maybe 5 minutes and then come to a stop before getting the dummy light to chime. But I can't see how warming it up a bit more and driving it around for 5 minutes could cause that big of a drop in oil pressure.
Not sure if it is something electrical or what. Before changing the oil, the old oil (with 10,000 miles on it) produced a bit higher oil pressure at idle. The wiring was bad but the pressure was just enough at idle to keep the computer thinking everything is OK. Then I changed the oil and the pressure is now a bit lower at idle. And it is just on the threshold and throwing the low pressure indicator now This seems like a long shot to me because the resistance of the sensor went down to 1 ohm when it triggered at 5 PSI and the resistance stayed at 1 ohm even as I went up to 40 PSI of air pressure in the test. And the 28 PSI I'm seeing at idle is way above the trigger threshold of the sensor.
So I'm kinda stumped. I think the truck can make the trip. It seems doubtful that the state of the motor would change much in one day after changing the oil.
All else I could think of was a bad oil filter maybe? Using Motorcraft FL 500S like always.
Thanks!!
150,000 miles
Thanks!!
