So I have a 71 400 block and matching heads that was "recently" built as far as know bored over cam piston heads and balanced. Bought the car with the stuff already done. my concern is low oil pressure, it runs at about 5psi at hot idle around 1000 rpm or so. Has mechanical oil gauge that has been changed since I had it. Old gauge's glass was busted but worked and read the same. The oil responds to the rpm. Id say 30 psi or so around 2500. Had a Melling high volume oil pump in it and just bought a new exact one and put it on and all psi reads the same. 50 psi cold idle. I know the difference between pressure and volume. I fear of putting a hv and hp pump in because no head work. Also id like to not worry about it being that's a terrible job and I do not want to do it again being its a 82 Camaro. I was told that as long as the psi responds to rpm I should be fine. Is 5 psi enough at idle. Thank you for your input.
