Hey all;
75 Monte Carlo, 400sbc, mild cam, aluminum heads, edelbrock carb. Nothing special. About 14* base idle. Around 34* total.
I've got the car running pretty good. She's little rich right now at the moment but will be fixing that this week (always like to run richer to start off, just in case). I was out driving her Friday night and she loves the gas at low to mid-throttle. Hauls ***, shifts fine, likes to spin tires randomly. Just tends to buckle a little at very low throttle from a stop, mostly after a good amount of throttle. I assume that's being caused by warm temps, or still excess fuel leftover. Just have to lean out some and I believe that will be all good then.
Anywho, anytime I've ever tried to go WOT, she not only buckles but wants to die completely. Last year she was bad, but had different timing. This year, no backfires or anything else, but just wants to straight die. I'm assuming the first place to check on why this is happening would be the carb. I'm assuming that the primaries are working fine, but maybe the secondaries aren't doing their job? They open, that's for sure. But honestly not sure if spraying properly.
Is there anything else that I should look at? Anyone else had anything similar to this problem? Thanks!
