I recently acquired a 1936 Chevrolet Master deluxe 2-door sedan humpback street-rod. I had to have the engine rebuilt, bad rod/crank. Anyway, the machine shop sent the car back to me with the original hoses on it which are leaking and I can not get them tight enough not to leak. I want to replace them, but can not locate a correct hose for it. The engine is 350 SBC with the short shaft water inlet, intake is from the passenger side with about a 1-7/8" outside size snout. The radiator appears to be an early Walker Cobra radiator with the 1.5" lower right side exit on the radiator. so that makes my needed hose as end "A" about 1.5" and end b: about 1 7/8" with a maximum total length of 13". I purchased a Gates 25526 vulcro-flex II hose 1.5" x 1-3/4" hose, it will not go over the water pump intake. I need to know if any other rodders had an issue such as mine and what lower radiator hose they used to resolve this issue. Thanks
Liberty5601
Liberty5601
