I'm in the middle of an LS swap restomod for my 66 GOAT and having interference issues with the "muscle car" oil pan the engine builder installed. It hits the front (stock) frame cross member and steering linkage. I was steered toward a Mast Motor Sports 409-069 cast alum pan which was supposed to be designed specifically for 64-72 GM A Body LS swaps. If the Mast pane doesn't work, I'll have to buy a steel pan and modify it as needed to compensate for any internal or external interferences.
In speaking with one of the techs at Mast who had a hand in the design, he shared that the test car for the pan design was actually his son's 69 Chevelle. He has no external interference issues in the areas that I have trouble which is promising but is the 66 GTO frame and steering linkage similar enough to the 69 Chevelle for me to expect their pan to solve my problems? The engine I'm installing is a 4.125 LS3 stroker with a full windage tray (4L80 trans). Internally, the pan should work because the builder has used this engine, windage tray and pan combo many times without issues. The problem seems to lie in how much alike the front frame cross member and steering linkage is between the 66 GTO and 69 Chevelle. Does anyone know how the two compare?
