rwc112 said:
I have a 94 LT1 Corvett block 4 bolt main, and a 2 bolt 93 LT1 out of a Z28 what would be stronger build 2 bolt with splayed caps or the stock 4 bolt?. was thinking of building a 396 CID (4.030 bore and 3.875 Stroke) but thinking a 383 (3.75 stroke)may be a safer build as clearance may be an issue. I also looking for info about the water pump I would like to use a belt driven Water pump instead of the OEM pump due to the leaking issues the Gear driven pump on the LT1 has I know there is a electric one but was wondering if the may be a aftermarket timing set cover and water pump I can use due plan to use a coil pack instead of Optispark and if I can get a belt driven water pump it would make things easier and less problematic.
The order of strength goes something like this: 2 bolt, 4-bolt, then 2-bolt block modified for splayed 4's. Unless you are going north of 500 hp, don't worry about anything more than a 2-bolt. 3.75 should not require clearancing if you use rod bolts that are designed for stroker applications. 3.875 and even 4" cranks aren't out of the question with a little careful grinding.
The water pump is not an issue at all. It is a beacon of reliability. Its the Dexcool that was the problem. A shaft driven pump puts no stress on the belt drive, and the belt yanking on the bearings is a thing of the past. I had to replace my LT1 water pump three times in the first 30,000 miles using Dexcool. After that I switched to green coolant and I'm now at 130k. That's 100k on this current pump. I have the pump off now to replace the optispark and I'm going to replace it because I have another one sitting around, but the bearings and packing around the seals looks A+. There is an electric option, but it won't help you. First of all, the electric options for LT1s (CS and Meziere) are terrible. They are billet bling that posers put on their LT1s to get that last 1/10 hp and it always ends up letting them sit at Burger King some night on the way to the cruise-in. Secondly, they don't replace the pump, they simply bolt on in place of the front plate and you remove the driveshaft from behind the pump. Its the same pump, housing, etc, just driven from a front electric motor instead of the driveshaft in the back. There is no belt-driven option. The water passages are LT1-only. There is no belt-driven water pump that you can put on that car. There is an optional heavy duty cooling setup that puts an idler pulley on a bracket in front of the water pump to drive a clutch fan, but the pump is the same.
Coil packs are a nice upgrade, but again... the Optispark is NOT an issue as long as you get a 96-97 version with the vents. Mine finally died at 130k (rotor broke). The "opti" part is an optical trigger that is incredibly accurate and very robust. The "spark" part is like any cap and rotor and can be replaced/upgraded. The bad press that the Opti gets is from (again) Dexcool. The Dexcool make the packing around the bearings fail, and the weep hole on the pump drips right on the optispark. I solved that issue by switching to green coolant, but some guys have epoxied in a little nipple in the weep hole and used some vacuum line or something to route any drips away from the Opti.
