1 - 6 of 6 Posts
I have a 74 Porsche 914 ( just got it painted black) with a SBC (350 pre 86 using edelbrock port injection) and a built 930 transmission, I would like an engine that will spin up to 8k. Do any of you know the details of building a 302 CID. I am open to suggestion you might have using other engines (327 ?). The 350 runs well but I think a package that likes to run a higher rpm might work out better in the long run. You tube video Your tube Video of V8, 914
John
Hates: Liver. Loves: Diesel
At 8k you should definitely use a 4-bolt block, but otherwise you're looking at putting a [forged] 283 crank into a 350 block. Bare minimum of forged (preferably non-twist) crank, forged I-beam rods, forged pistons, and solid lifters. I've seen 8k small blocks running hydraulic lifters, but its not common.
Something else to consider... a 321 built with a custom 3" stroke (large journal) crank in a 400 block.
A 283 is small journal and a 350 is large. Better to run a sj 327 block and 283 crank which are all forged - at least the ones we saw here were. Small journal cranks in LJ blocks require bearing spacers which gets ugly in terms of heat transfer.
If your driveline is marginal - like most porsches then by all means build a 'revvy' low torque engine, but do the maths, you may find a 327 at 7 grand will smack that 914, and give you plenty of roadspeed.
Banned
We build a few circle track engines using 283 mains in a 350 block and Honda rod journals and as far as I know no one is using bearing spacers when Clevite makes a bearing for that application P/N MS-1110-H
I would go to a 350 block as it has better webbing then the old small journal blocks a block with center caps that say 2482 on them would be a good choice.
And we have installed splayed caps on the old 327 blocks on the ones that the cylinders sonic tested good.
My sj 327 has splayed bolt caps but they are unlike any others I've seen- more like a half moon in shape, unlike the stepped summers bros and milodon ones in common use here.
Is the clevite part a thick wall like the trw 400 main/350crank one piece bearing?
Ian.
1 - 6 of 6 Posts
