I have a th350 with a trans brake and I want to get rid of the transbrake, can I have a reverse pattern manuel valve body installed in this tranny and be rid of the transbrake or when it was installed did they drill something and now that can't be done , if it can which brand for the money would you suggest to install,, I am no transmission person so all I know is the guy who installed it say's it has all TCI parts in it..I bought the car this way
Thanks
Dan
Every transbrake valve body I know of for the t-350 uses the reverse shift pattern....
Does your valve body need the solenoid activated to back up?
A reverse pattern valve body should bolt onto the case with no changes.
transbrake
Yes I do have to activate the selinoid to back up , problem is it stays engaged and I want to just be rid of it and put a reverse pattern without the transbrake and was wondering if it was possible,
Thnaks
Dan
