what parts will i need to use to build hi torque 383 stroker marine motor
My bad, I went back to the Dyno sheet 541 Torque @ 5071 Rpm. Dart Block 402 C.I. Small Block. Sorry was thinking old 383.richiehd,what 383 that you know of has peak torque @ 5500 RPM?
I wouldnt want to run a boat engine above 4,000 myself.Thats where I would set my max power unless it was a racing boat or ski boat?
How many gallons per mile does the boat get like that.
That sounds like a 600hp engine.
He should be able to turn a pretty fat prop with a 4000/4500 rpm tq peak. Should also not be to bad on gas at part throttle and still move a larger boat.
QUOTE]
Yeah, his skiff will burn through 20 gals of gas on a day river cruise, no problem. 523 HP to be exact. Spins a pretty big 2 blade @ about 80 mph.
Funny thing though, I turn my 283 6500 and run right there about 77 MPH, so big cubes and HP isn't everything. Drag and handling become real important when it comes to going fast on water.
Although a 180cc runner is about right I wouldn't use the SHP heads, if you're going to spend the money for some nice ones I'd look into some Profilers for an "as cast" head.Dart SHP 180cc Straight Plug Aluminum Heads,GM Hi-Performance 4 Bolt Block(new), Hydraulic Roller Camshaft,edelbrock performer(air gap),nodular or better internal balanced 3,75 stroke cam,hyper or forged pistons,keep compression around 9-9 1/4 for a boat, the engine like this would cost me about $7,500,not cheap and likely 430-440 hp at 5,200 RPM.
power can be adjusted up or down as required,your choice.Im thinking an engine that will last years and be reliable.
are you planning to use fuel injection or carb? for skiing F.I. would be nicer. what kind of exhaust manifolds are you using? wet or dry?
an engine like this would make around 300 hp as low as 3,000 rpm with peak torque around there depending on camshaft chosen.
When I built my 434 I purchased my parts from eastern states and had them air freighted to Vancouver Canada,it was cheaper to ship than the hood I bought in California and had sent by truck.Look into freight costs and see if you can get a package sent?
like i said the boat is not for racing but should be able to pull skiers easily and have some fun it look"s like the cam is very important any part numbers that i should look at? exhaust's are wet as i understand (big bulky and don't look like they are in very good condition QUOTE]
Jerry,Get yourself a marine performance cam.You should stay under 280 degrees duration. When you call the tech line for help make sure and ask them about water reversion, if the guy says "What?" hang up and move on!! Then contact Jones Cam Design in North Carolina
If you are to take full advantage of all that horsepower you are going to have to step on the exhaust. Glenwood makes an excellent exhaust log and elbows that will not be that of a header but much better than cast iron manifolds. A little pricey but worth the investment and will give you years of service, plus they look great! Glenwood located in California USA
