Hi All:
Tonight I ran into a bit of an issue and was looking for some input from you guys. I need to make a new threaded power steering/AC pump bracket rod. I have the original but it no longer fits since I moved to GT 40 heads. The threaded holes in the GT40's are 7/16 where on the originals ones where 3/8's I was thinking of going to buy some 7/16 round stock and just recreate the part on the lathe.
I was thinking of either threading one end 7/16 and then machining the rod down to 3/8's so the brackets still fit and threading the other end 3/8 like normal. Or I can drill out the brackets (as long as there is enough material there) and just using the 7/6 rod. I like the latter because it should be a stronger part
The question is what type of round stock should I look for? Any other ideas I'm open to as well
Thanks
Mark
Thanks
Mark
