When determining rim width for a tire application which do you use "rim width" or "overall rim width"
As noted here:
http://www.usacomp.com/terms.htm
"rim width" is measured from the inside shoulder to the inside shoulder of the rim lip (where the tread seats) while "overall rim width" is the distance from the very outer edge to the very outer edge of the wheel lip. Which of these two do tire makers use when they provide their "approved rim range" for their tires.
If it's "overall rim width" it seems to make sense for the rims/tires that were original on my 81 F-150. If mfrs. use "rim width" then everything goes out the window. The actual "rim width" (inside shoulder) on my F-150 stockers is about 5-5 1/4" , yet the Dunlop tire site says the recommended tire for this vehicle is approved for rims from 6" to 8" wide.
On the other hand the actual "overall rim width" on the F-150 wheels is just about 7". This puts the tire Dunlop "approved rim range" right in line with my 7" wheel width.
Any tire/rim experts out there?
As noted here:
