So the thing that's really going to matter is how the gauge operates.
You're saying it's an "electrical" gauge, but some people are referring to "digital".
So we need to discern between "electro-mechanical" vs. "digital".
Some electrical gauges use the "bi-metal" thermal operation, which takes time to move the gauge.
They're only good for things where the gauge only needs to change gradually (fuel, temp).
For anything that changes quickly, mechanical is much better.
If the digital sending unit and gauge show instant results (I'm assuming they should), then that should work just as well.
Example:
I had bought an electrical trans pressure gauge, and never gave any thought to how it would operate.
Once I installed it, I realized that it couldn't give me a readout of the trans pressure as it varies with the throttle.
So I had to get a mechanical gauge for that.
The electrical would've been fine for a tow vehicle, just to make sure you have good pressure as you're cruising down the highway.
But to be able to monitor instant pressure changes as the throttle varies, it had to be mechanical, although I'd assume digital could also give you instant results.
