Got a 11:1 SBC 383 with a Holley 750 HP series double pumper (mechanical secondaries).
When the motor is not running, the secondaries close very easily by the spring. I can flip them open and they close very well.
I've got the primaries set to be open enough to idle at 1100 RPM. When running and I blip the throttle, the primaries close all the way but the secondaries stay open enough to keep the motor running at around 2000 RPM. With my hand I can turn the secondary throttle shaft that last bit to close it and then it'll go back down to 1100 RPM.
It feels like the motor is sucking so much air that it is keeping the secondaries open. This is a brand new carb from Pro Systems. Not sure if I need a heavier spring on the secondaries throttle shaft. Or if I need to tweak/bend the linkage between the primaries and secondaries.
Thoughts?
Thanks,
Sal
Thoughts?
Thanks,
Sal
