Just thought Id share some metal finishing pictures and do a quick run throu of the process I did on my current project 1949 chevy truck...Eric
Please bear thru since for some reason I cant post the acutall
pictures.
http://www.imagestation.com/4325757/...757/3960670479
Picture shows bare metal before I started
www.imagestation.com/4325757/3960670477
This picture shows the "guidecoat" that I use to find the highs and lows. Same idea as when blocking primer prior to paint.
www.imagestation.com/4325757/3960670310
www.imagestation.com/4325757/3960670305
Picture hows after I ran a block over the metal showing the damage. the shiny metal is the high spots and black areas are the lows that I will bring up.
www.imagestation.com/4325757/3960670181
Picture shows the track marks from the hammer and dooly process. If you look at the black areas you will see small spots of shiny metal inside the black areas. This is a KEY process to metal finishing, seeing what you are doing.
www.imagestation.com/4325757/3960670138
www.imagestation.com/4325757/3960670122
Picture showing the process. Did some hammer work then ran the block over the metal again. As you can see the size and number of black spots is getting smaller.
www.imagestation.com/4325757/3960670054
Good picture of the process and damage getting smaller and smaller.
www.imagestation.com/4325757/3960669846
Picture after the shrinking disc has been applied to the metal. The shrinking disc lows any high spots in metal, by causing friction which in turn causes heat which in turn again causes the metal to shrink or compress
www.imagestation.com/4325757/3960669844
www.imagestation.com/4325757/3960669767
Another shot of the disc work. As you can see the metal is pretty darn straight. At this point you could prime the metal block sand and prime again then paint. But we are going for a level of smoothness that needs just 3 coats of primer then paint.
www.imagestation.com/4325757/3960669595
Picture of fender after two rounds of disc work and hammer work. This section of fender is done and ready for paint. But in all reality I would work the whole fender rather then do them in sections.
Link to entire photo process, its very basic but another album within shows the tools that I used on a 72 truck fender,
http://www.imagestation.com/album/pi...?id=2099542273
Thanks for looking and enjoy...Eric
subscribes.. :)
What are you using for the guide coat.. I've always been into learning this stuff.. but never had any training.. I would love for someone to walk me through the stages..
Things look awesome.. keep it up..
