In the process of painting my car, which I chemically and mechanically stripped entirely down to bare metal, I was told by the paint supplier to apply POR's Metal Prep to create a phosphoric coating that would need to be washed thoroughly after it remained wet on the surface for 15-30 minutes. That done, I should next have to clean with a wax/grease remover and apply my filler/primer prime coat.
Days after I finished rinsing the Metal Prep, I noticed a golden tint over most of the car. At close examination it appears to be veins of surface rust (see pic).
Called POR and they told me it is only made as a prep for POR-15 rust paint and not to be used directly under other paints.
Time wasted, labor wasted...now I have to sand entire car to get rust and this crap off the car.
Any suggestions as to what I should use as a rust converter before applying paint?
Thanks
Thanks
