Application:
- 383 SBC
- AFR 210 Comp. Ported cylidner heads
- Solid Roller, 258/263 @ .050", .668" with 1.6's
- 4-speed Borg Warner Super T10
- 3400lb '72 Nova (guessing here)
- 8.5 GM Big 10 bolt, 4.11 gears
- 750 Mighty Demon, Annular Boosters (I probably should go bigger, but this can work for now)
I am having some tuning issues. Symptoms include: what seems like a VERY bad bog and general just sluggishness in every gear. It would seem as if it's too rich, but my idle mixture screws are 3/4 a turn in! I'm confused, as it is my thinking that an off idle bog indicates an over-rich condition..? The manual states that it should be between 1 - 2.5 turns out. Can someone clarify how I should go about tuning this?
I followed the advice given here:
http://moparchat.com/forums/showthread.php?t=56317
..but am unsure if all of it apply to SBC's, or my application (would imagine so, can't think of why it wouldn't). I followed the directions given here, but got lost/stuck at the part where it mentions going in 1/8 turn after hitting the accelerator pump. When I do, my engine just DIES (yet again, indicating an over-rich condition). I don't want to lean it out too much and am coming here for some reassurance. The only way I could get my car to idle correctly was to set the butterflys open way more than .020 - .030", and am curious as to if that would cause the stumble..but I can't get the car to idle right at all without the butterflys being open. The carb is not equipped with Idle-Eze it would seem, as I cannot get the screw in the middle to turn (it may not be a screw, it's really hard to tell)
I do want to tell you that I am new to tuning carburetors. There is no snap in the throttle when I stomp on it. Every gear that I go in, there is a stumble (idle into 1st, 2nd, 3rd, and 4th). Any help from you guys is appreciated, and maybe [email protected] can help me out. I know he has been a help before.
..any help is appreciated. Point me in the right direction please..
- 383 SBC
