Ok, i have a 2 bolt main 1973 454 that i am going to have machine.
The heads are 353049 castings, which when i looked them up, were made: 1970-73 with an Open Chamber and 113.0cc.
I'm going to reuse the rods and crank. The heads will have new springs, guides, etc...
I always thought HIGHER COMPRESSION = MORE POWER. I'm going to go with some hyperutectic pistons, but what compression ratio should i shoot for? This is a pump gas motor.
What PISTONS with what CAMSHAFT should i use to get a good street/strip motor? (this is a buget power motor and i don't plan on buying a really $$$ cam. I'm planning on a new flat tappet hydrolic cam OR a USED solid roller cam.
I know this isn't a lot to go off of but i'm NEW making BIG BLOCK power.
