1 - 8 of 8 Posts
:welcome:
Hi guys.
I have a hitachi mini starter installed but it completely misses the flexplate no matter which position I mount it in. It seems the gear just doesnt extend far enough. Anyone ever encounter this? Engine is a fresh build and I havenot tried a regular starter but opted for the mini for header clearance. Any suggestion greatly appreciated.
168 tooth for a mark IV 454. I was told that my starter would work with either, just a matter of using the right mounting holes. I do believe Ive tried them all. :( Any other possibilities? I surely hope flexplate not on backkwards. It would be such a pain to have to pull everything back out of this car.
That starter should have four holes, two align it for a 168 tooth, the other two for a 153 tooth. There's about an inch difference between the two. Double check that. Flywheel may indeed be on backwards as that's somewhat of an easy mistake.
I don't think the flex plate can be on back-wards. The mounting holes are not symmetrical such that if you turn it around, it would be impossible to line all the bolt holes up.
I beg to differ. Trust me i just flipped mine around in my v8 s10. 6 hours of rolling around on the floor to turn it around. Not a fun task.
I think you are right....he said irs a 454, which, being externally balanced, would only go on in one position.
1 - 8 of 8 Posts
