Hey all. I have a 92 K2500 with 350. Couple years ago i did a TBI to carb swap. Ran fine until couple weeks ago. Just put an RV cam in and first issue was , rocker studs began to push out. Going to swap heads for ones with threaded studs. It ran fine until the other morning. I started it and now its missing on #8. Ive swapped the cap , ( HEI ) , plugs and wires and still missing. Did compression test and was fine. Could it be the coil in the cap ? Maybe the hole in the head ? Im at a loss. Thanks in advance
