Help with clutch
hi again, I posted the question below a week ago and had some of you suggested I had the wrong throw-out bearing as there is a short and long throw-out bearing and that I probably had the wrong one installed. Since then I popped into my local parts store and ordered a new throw-out bearing specifically for a 66 corvette. I dropped the transmission and to my frustration found the throw-out bearing to be the same size as the new one I just picked up. I am left scratching my head again. Is it possible I have the wrong bearing again? Can the clutch for pivot stud have anything to do with this? Or as the car came in boxes could it be the wrong clutch fork or bell housing causing this problem?
Any direction would be greatly appreciated
I am hoping someone can help me out, I year ago I picked up a 66 project corvette. Much of the car was in boxes and there was no motor or transmission. Since then I have redone the chasse, picked up a 427 engine, Muncie M21 transmission, installed a centerforce clutch and have dropped it back into the frame. My issue is that the clutch pedal only starts to engage if I have the push rode adjustment backed all the way to the end of the push rod. I know this can’t be right but don’t know where to start trouble shooting? I am hopping i will not have to pull the motor and tran out of the car !!! any help would be great.
thx
thx
