The patch panels that were on it are still around. I could just use those. I did that on the 33. Perhaps I should insist on new full quarters and door skins?
Alright, point taken. I don't know any better due to lack of experience. Is it so much so that I should confine my patch to the bottom six inches and rely on straightening and blasting to save the rest?
I had four rides at one time. Only sell if unemployed, in the past. There have been a few I would still have if they were not either destroyed or sold to make the mortgage. Current earnings fall way way short of life requirements and theres only one V8 left. :sweat:I really like the As get cant fit in one after the interior is installed,lol,,i had one years ago early 90 ,,I installed a Mustang SVO engine and trans & rear,,didnt get the front installed before I sold it,,that is always my problem ,,I sell them,and wish u had not.
I am certainly no expert on them. Every car is just metal shapes. 65-75 GM stuff, I understand.
Guy who put the engine on the Model A chassis wants plywood encased in welded shut metal, for the front floor. Y'know, build floor, lay plywood over it then stack another pan over that and weld it in. Thoughts?
So you would be right at home with these,I am certainly no expert on them. Every car is just metal shapes. 65-75 GM stuff, I understand.
Its a Model A and T and maybe even B... tradition. Not necessarily to have wood as, but wood in, the floor. As insulation. Wood is all through the original construction, ours will be metal. I got some 1 1/4" square 14 gauge tubing today that fits inside the existing B pillar. One ten foot stick of that plus two of 1x2. Theres a whole bunch of 1x4 tubing that was bought for this job, so I will use that for some places on inner structure. And I collected an angle iron X that might be useful for bracing and jigging, from the might be useful pile. Only took one pic this afternoon but I guess I skipped lunch posting so there should be an AM pic too. Story later, must mow. And the GTP wanted to overheat on the PM, only 85 out commute. Perfect. Supper plan B, she wasn't gonna make it through a drive thru.Can't find one good reason for this.
Is he worried the motor will grenade?
It would need to absolutely water tight so the wood doesn't rot.
It will still rust a bit, not rust out, in there regardless from condensation.
Howdy!Hoo boy, Gary found you a REAL project this time...
When I was looking for a street rod, I deliberately avoided anything old enough to have wood inside. I can't deal with wood, or fabricating replacements for it. This will be interesting to see how much of what you were handed is left when all the mods/rebuilds are done..
The hood clearance on the Cat looks like an issue. Where would an air filter go, or is the cover on the injection body high enough to simulate one ?
