Motor was running pretty poorly today while I was out shopping with the wife. The sound it made, and the response of the motor told me I had a bad miss or a dead cylinder.
When I arrived home, I began pulling plugs. The second plug I removed was wet and sooty. This was not good
The thoughts of a holed piston, or a flat cam lobe raced through my head, and I was thinking that perhaps I should not have recently spent a couple hundred on some tools I wanted, as now I might need that cash for parts, Bummer. :drunk:
I examined the plug wire from the dead cylinder and found that the insulation had cracked and burned through, and was shorting against my headers.
My question is this;
Is there any way to know if the plug wires I am buying will be long enough to route them away from the headers? I began running the plug wires, and every time, it seems like I end up with some that are too short to finish the job!
How can I tell how generous the length of the wire kit is, other than "buy then try"..
