1 - 2 of 2 Posts
Hi, I have been trying to spray a single stage orange metallic and avoid stripes and mottling however after spraying clear over the panel I noticed some mottling and stripes. I know I should of more carefully drop coated on the final coat while it was still wet but I didn't and now it is fully cured with a few coats of clear on top. Is there anything I can do to reduce the effects without reshooting the entire panel. It is a 50 chevy truck cab so reshooting an area pretty much mean reshooting the entire thing but the worst area is the lower back of the cab and I think I could mask it off at the beltline. Is it possible to scuff the surface and put a drop coat on and reclear or would that just make thing worse? anyone fix this problem on cured paint before?
point on positive
I'd say tape it off like you said then a quick scuff with 400 just to level nibs without cutting through the clear that is there ...then fog the color on with higher air and from about 3 feet from the panel to cover the stripes knowing your going to clear coat again...
put the color on kinda dry and get the gloss with the clear...
1 - 2 of 2 Posts
