Is this safe? I've heard that If the mounting point isn't above your shoulders or equal to them it will compress your spine in a collision. I'd put a roll bar in but I don't want the back seat to be out of commission.
Having the belts anchored to the seat is not legal. The best way would be to have them anchored to the required cross bar. This from the NHRA rule book: "Sidebar must be included on driver's side and must pass the driver at a point midway between the shoulder and elbow. Swing-out sidebar permitted. All roll bars must have in thier construction a cross bar for seat bracing and as the shoulder harness attachement point; cross bar must be installed no more than 4 inches below, and not above, the drivers shoulders or to the side bar." There are more regs on bracing etc, so I suggest that you get a rule book and look up 4:10 ROLL BAR on page 261.Tomlowe523 said:If I get an aluminum seat from Kirkey or something could I weld blocks on to the back of the seats then drill and tap them, then bolt the belts to the seat?
Son, don't tell me you're going to have shoulder belts on if you're on a double date. Get real.Tomlowe523 said:That would still make the back seat unusable. At the very least inconvenient to sit it.
techinspector1 said:Son, don't tell me you're going to have shoulder belts on if you're on a double date. Get real.
