Unless you're swapping cams frequently the extra cost of a two piece timing cover isn't justified, which is why most people don't use them.Max Keith said:I am curious as to the benefits of running a two piece timing cover. I have seen them in parts catalogues forever, but none of the Stovebolt (Bow Tie) guys I know ever used them.
I might have to look into that. Maybe I'll try that on mine. How much clearance wat there? Do you think there is enough for a 10/32" screw?nabx22 said:I have fixed this cover by taking it back off and drilling it at the bottom for three screws .You do not have to drill the block just both halves of the cover then install sheetmetal screws at the bottom tighten the three small screws at the bottom before tightening the rest of the cover.I dont know why Mr.Gasket didnt design it this way to begin with.Just wanted to let you know it could be done in case anybody else has this problem.
On my 400 I used oil pan studs. I also have a windage tray. There isn't enough room for the nuts to fit over the studs. The cast in washers on the nuts don't clear the edge of the pan. If I ever had to pull my oil pan off I am afraid I won't be able to get my pan back on.Max Keith said:Could it be a status thing like chrome rocker covers?
