Hi Topher5150, I'm a firm believer of the MSD ignition system, have been using one for years on my chevy's, it gives you a hotter spark and longer spark duration, excellent for fuel economy and performance. You don't need to be drag racing in order to enjoy fuel economy and a mild horse power boost, also give you great throttle response, setup properly you really feel the difference of the extra sparkage in the cylinder chamber.
With that said, the MSD system is pretty straight forward and gives you provision to use it with an MSD ignition system or the stock system. I would recommend running MSD 6AL through a blaster coil feeding into your stock distributor, you should look up instructions on removing the hei unit if you're using the blaster coil. I also have the MSD billet distributor which is fully controlled by the MSD via a harness plug. Depending on your application there are different wires in the harness to use, follow the instruction in the kit or on their website, very helpful.
As for testing it, that depends on the unit you have but very straight forward, the digital ones have a green light letting you know its live, wire it up through to your HEI or Blaster Coil and run it to a single spark plug removed from the cylinder and give it a spin, you should see a continuous spark stream from the plug, its as simple as that. MSD have great instructions on their website for every application type and there are dozens of videos on YouTube you can watch. Be Very CAREFUL! the voltage coming out of an MSD system is serious.
Good luck on the project friend, keep us posted of your progress!
