1 - 2 of 2 Posts
· Registered
Stock Mustang II crossmember install question.
Does anyone know the distance from shock tower center to center? I have searched probably 100 threads and no luck. I have the stock crossmember in my 38 chevy but I had to cut the middle, bend it over a wheel and then slide it up over the frame rails. I pulled the crossmember together with a come along but now it sits at 34 inches center to center. For some reason I was thinking it should be 35 to 35 1/2 inches??? Also will this be a problem if it stays at 34 inches? Thanks!!
· Registered
I don't think the overall dimension is what you need to worry about. It should be the relationship between the lower "A" arm mounting hole and the upper "A" arm mounting holes. The distance between the top hats is pretty much irrelevant (except as it relates to the rack width).
Centerline
1 - 2 of 2 Posts
