Mustang II suspension issue
8K views 47 replies 12 participants last post by  mainstreetprod
Returning to street rodding today after a 43 year absence! Just like riding a bike, except I missed out on the whole "drop in a Mustang II suspension" thing. My '41 Lincoln street rod, delivered today, has one and it rides like a buckboard. Looking at the springs, they appear to be extremely short, which would explain the lousy ride. So I ask of all those familiar with these installations- what's the cure? And if the answer is replace the spring with a full length one, how the heck do I figure out which spring to order to keep ride height the same?
See less See more
1
#2 ·
Mii
That appears to be a stock MII unit right from the junkyard and has been converted to coil over shocks. It also appears to be a power rack, correct? Are the lower A arms parallel to the ground? It also looks like the springs have been adjusted up to put more tension on them which would reduce travel and give a harsh(er) ride. Do you know the weight of the vehicle? Take it down to the local truck stop or wherever and get the front, rear and total weight so that a proper spring can be ordered. What are you planning for upgrades? What is the rear suspension? Pictures of the car too please.
Correct.
Yes
Probably adjusted this way to lower the car, but results in a harsher ride
Probably around 4000 lbs. It's 4300 curb weight with the V-12 and estimate the 350 SBC knocks 300 lbs off. Not sure how the Mustang II vs transverse leaf affects the weight.
None, just want to maintain ride height and improve the ride
Conventional leaf springs, transverse leaf is gone. 9" Ford rear.
#4 ·
I agree with 39 master. Get the car weighed front and rear. Try and get a straight on shot of the suspension on one side.
Just looking at this picture it looks like an aftermarket chrome spring. These only come in 375, 500,700 pound ratings. They are short than stock to get the ride height down. In any event it’s important to get the lower arm parallel to the ground. There are dropped spindles available from a number of suppliers to help this.
You can also use an anti roll bar. There are several available.
For now that’s about all we can do until you give us more info.
Typical coil over shock conversions like this are very stiff. I’ve had my adjustable shocks revalved a couple times but they still were very stiff. It doesn’t look like yours are adjustable. There would be a small knob at the bottom by the control arm.
#8 ·
I probably need stock springs so there is sufficient suspension travel
Brakes upgraded to 11" rotors from Speedway.
Mine look like 9", I'm sure I need this upgrade
As suggested, get your car weighed and get springs correct for the weight.
I can probably do that at the county dump, where they weigh your vehicle before and after. Not sure if that alone will tell me the correct weight. From what I've read, the engine sets back much farther in a street rod than in a Mustang II, resulting in less weight on the suspension than you might think.
[/QUOTE]
#9 ·
The springs shown with the coil over shocks appear to be shorter than stock. Then to get the ride height they are adjusted up what looks to be about 1 1/2 inches. These shocks do not compress the spring. They only provide ride height adjustment.
Mainstreet.. is probably right, you need a stock type spring. There are several rates available in the like by inspector. You would use a stock type shock too.
#10 ·
Would like to avoid having this done at a shop, but the job is a bit out of my wheelhouse- especially concerned about compressing the spring with a tool as described in multiple Youtube videos. Can the spring be installed by putting the front car frame on jack stands, removing the spindle, dropping the control arm with a jack, replacing the spring and jacking up to compress?
#11 ·
Suspension
The shock and spring are one unit that would be removed together. I think you are looking at the procedure for coil springs.
Just unbolt the shock top and bottom with the car jacked up far enough to drop the coilovers out the bottom. If you don't have the spanner wrench to undo the spring nut a local repair shop should have one. Not to worry, the spring will not go flying and it's best to lube the threads before undoing the nut. Once the spring is removed you will be able to check the shock for proper action.
#12 ·
I was looking at the procedure for coils because I was considering replacing the coilovers with conventional springs. However, I don't see any reason why coilovers wouldn't work if the springs were not so short- most I see in internet photos are nearly the full length of the shock.
#17 · (Edited)
Determine front weight per Fang 16 video. Jack up front of car. Loosen adjusting nut on bottom of shock to relieve spring load. Remove shock and spring. Measure diameters, length, and coil wire thickness. See below and call Speedway. Buy springs only if shocks are good. Reinstall and adjust nut for ride height.
https://www.speedwaymotors.com/QA1-...MI36nEv-DF4AIViR-GCh2_GADfEAQYASABEgKVZvD_BwE
Below are springs only:
https://www.speedwaymotors.com/QA1-...MItqWkx-TF4AIVlVuGCh1I6AckEAQYAyABEgLRLfD_BwE
#18 ·
mainstreetprod
Where are you located? I likely know someone near you with a spring smasher to figure the rate, then we can recommend something in about the same rate but 3-4" longer. I'd imagine that spring is coil binding or getting too close to coil bind and the rates will sometimes get way off when you're that close to coil bind.
#19 ·
I'm located just north of Nashville TN. I believe the springs for Mustang II front ends are generally 500, 600 and 700 pound. I would assume with this Lincoln I would need the heaviest capacity?
Also, my car still has the stock lower A arms - will the coilover drop through the bottom when unbolted?
#24 · (Edited)
I have a similar setup as yours in my 46 Ford Coupe (stock mustang II with coli over conversion). I'm sorry that I can't help you with spring rates since I can't remember the exact springs I used. It's been in service for over 20 years.
My car weighs about 3900 lbs with me and a half tank of fuel. I'm pretty sure I used the heaviest springs that I could get at the time. Seems to me that I started out with 500 lb springs, but they sagged pretty quick and started looking like yours. I think I went to 600 lb springs after that, but I notice that they might need to be replaced on the next freshening up I do on the car.
What I can tell you for sure is that removing the shocks and springs from mine is a more difficult than just unbolting them and dropping the control arm with a jack due to the deep construction of the stock stamped MII control arms. The strut rod rubber bushings will not flex enough to allow them to come out this way. I have to unbolt the struts from the lower control arm to get enough travel. I seem to remember having to break the lower ball joint loose, too, but it's been a loooong time since I had to pull them out.
You may have a tough time getting good suspension travel and keeping the ride height that you have now without going to dropped spindles. you can adjust the control arms for good travel and still get 2" lower ride height. Just a suggestion.
Also, I have looked at several stock MII's (the actual Ford car) and they all have the lower control arms running slightly downhill toward the tire when viewed from the front. This is because, on the stock stamped CA's, the center of the pivot bushing is not directly in line with the center of the ball joint ball when the CA is level. Having "level" control arms means having a line drawn though these pivot points level. Tubular CA's are not made like this and they will be level to the eye.
#26 ·
What you have is an early aftermarket cross member kit. A stock crossmember has a rolled edge to strengthen the spring tower. Also the tie rod ends have been lengthened to accommodate a longer spread distance from one side of the frame to the other. The lower control arm should be angled down from the pivot bolt. When it is level, you are 3/4 of the way through the stock travel.
#28 ·
Makes since that this is an early crossmember since the rod was built 15-20 years ago. I'll keep the control arm angle in mind when swapping the springs, not sure what the actual angle is since the car is so low and has been in my small garage since I bought it. All I have is the one picture to go by and the angle it was taken at could affect the perception.
#27 ·
To date I have installed over 50 stock mustang 2 cross members . The early ones have a T shaped bolt that drops down into the cross member and turns to hold the upper control arm, the later ones have a river head bolt that is installed from the bottom of the spring tower. Also there are 2 stock widths on the crossmembers , measuring the spread of the lower control arm pivots
#29 ·
Start with the given. From the center of the spindle to the floor is about 12 inches, look at the car and see what the tire/ wheel clearance is to the fender opening. You can go with a longer spring/shock setup and then put a set of dropped spindles to bring the ride height down. Ideally the lower control arm pivot bolt should be 12in To put the control arm in the proper place.
From the picture, there’s a lot of work to be done. It is almost worth it to start over with a newer cross member setup. The first attempts at cross member kits were not that good. That’s why I stuck with the oem cross member. The first one I did was 1976. 1936 Plymouth sedan. 13 years And 147k miles. Sold it to a friend who is Still driving it.
#30 ·
Today I was able to drive the car a much longer distance. Rides much better than I thought- the roughness was flat spots in the tires that went away after a while. Did bottom out on a large speed bump, but does have some travel. Still a bit stiff and could use some improvement, but not bad and perfectly acceptable for a street rod. The lower A arms, looking under the front for the first time, are exactly parallel with the pavement. I believe it was you that posted they needed to go slightly downhill from inside to outside pivot?
Brakes are another story. The stock (I assume) Mustang II brakes with under floor power booster are very weak. They will bring the car to a stop, but can't skid a tire and are reminiscent of mechanical brakes. If anyone is using similar brakes on a car of similar weight with better results, let me know. Speaking of weight, I tried the Youtube "posterboard" method and came up with a whopping 5400 pounds. That can't be right- original curb weight was supposed to be 4300 and this car has a small block, not a V-12. Should be closer to 4000. I'll take it to the scale at the county landfill.
#31 ·
As for brakes. If you’re running a GM rear end go with 69to 72 Camaro rotors and calipers Use the inner and outer mustang bearings with a National oil seal 50409. if A Ford rear use Granada rotors. They willing handle the breaking chores. Brake caliper brackets are available from several suppliers
#32 ·
So can someone tell me what would happen if I simply adjusted the coil over adjustment nuts downward, say an inch? Obviously suspension travel increases, but what happens to ride height and lower control arm position? Right now the bottom of the stock arms are exactly parallel with the pavement.
#36 ·
Adjusting the nut downward will lower the ride height. It will not change ride characteristics. If you don't believe us, try it and you'll learn for yourself. A number of people posted "you need a stiffer spring, higher load rating, or a higher spring rate". They all mean the same thing. You have too much weight up front for the springs you have. CHANGE THE SPRINGS.
#41 ·
Keep in mind that any kit that uses Granada rotors will widen the track about 1" (1/2" per side). The Camaro rotors may do the same, but I have never used them.
There are some kits that use custom hubs and separate rotors that don't change the track as much. I have a Baer kit on my current project that only adds 1/4" to each side.
Check tire clearance to the fenders well to make sure you don't run into trouble.
#45 ·
On my Pontiac the front track width was about 3 narrower than the Camaro rear track (some of that was the tires, 235 vs 215), and I had plenty of clearance inside the fenders for the wider front track. Mine had GM pattern 9" rotors when I got it, didn't have any worries about spacers/adapters.
#46 · (Edited)
Bob, I have a question for you or anyone else familiar with stock 9" brakes on large street rods (say 3500 lbs plus). I would expect lackluster performance since they were designed for a Pinto, but mine seem worse than that- stepping on them is very similar to a mechanical brake system, not remotely capable of a panic stop, "stomp and pray" . The only car I've owned with brakes this bad was a 1919 Chevy. I'm wondering if something else is wrong with mine. I have jacked up the wheels and confirmed they all are working. Also confirmed that my brake booster is operational.
As far as the track goes, checked today and found the rotors have 1" wheel adapters and front track is narrower than back, so any widening of the track by a new disc system, won't be an issue.
#47 ·
My braking issue started with the booster that was on the car went bad. It was reputed to be from the same '74 donoor that the front clip came from. There is only one booster offered for '75-78 MII, and it didn't match up with what I had.
I went with an after market 7" dual diaphragm booster, dual MC with proportioning valve combo (brand new) I got from a friend. After mounting and making adjustments to get a straight push from the pedal to the booster, I had better brakes, but they still seemed a bit weak. That's when I went for the 11's. Better, but still not quite right!
Finally figured out the proportioning valve was for 4 wheel discs instead of disc front/drum rear. Changed that out and now have proper braking.
Might possibly been OK with the original 9" discs, but like cubic inches, you can't go wrong with more brake power!
