wow. Is there really any other word for that thing?
K
K
I'm on it.Dusty82 said:I mean, can you imagine seeing that 1100 cubic inch engine powering a t-bucket?
Dr. Fresh said:I wonder how much power it will make when finished. It would have to make way more than the stock 500hp to make it worth the weight. 1000 tq sounds fun though!
These engines were originally built by Ford in WWII as V12 airplane engines, but the military really needed a good tank engine at the time. Ford responded by chopping off 4 cylinders off, and adding an 180 degree crank, so was born the GAA tank engine. The modified heads on my engine were spares for a GAA powered tractor that won the nationals back in the eighties. It made 3600 HP using twin turbos, 34 pounds of boost and alcohol. The engine had a stock crank, stock rods, and stock cams in it.killerformula said:Yeah they said it can put out quite a bit more with nearly stock parts. I wonder what that number is?
God, I wonder what that thing sounds like?!
K
What type of tires will you be running?900 HP @ 4200 rpm, and 1300 ft. lbs. of torque, with over 1000 ft. lbs available from 1600 to 4200 rpm.
