I just replaced my transmission pan and Seal and put 5 qts in it I also let it worm up and put it through the gears and it shows up just above the add mark on the stick do I need to put a 6th qt in
Ok I will do thanks I aslo have another question the new pan and seal are still leaking not bad I tightened all the bolts n don't know were to go from there
your talking about the pan gasket . correct .. never over tighten the pan bolts.
I can't see the pan gasket leaking unless was installed with a sealer on it .. I use 3M spray glue on the pan side of the gasket .. let it tac and put it on .
