machine shop tom said:
I'll go ya one BETTER! The Mac OS10. Linux based, Macinitosh usable.
:thumbup:
tom
actually it's BSD based.
1Fast65Elky said:
I wouldnt have said that if I'm not in the same situation.
I got 2 128mb (256mb) ram chips installed and it only recognizes 127mb and still runs. I guess my pc is the only one in the world able to run over rammed.
Some webcam shots of my ram and a screen shot of my system properties to show that I have 2 128's installed and only recognizes 127?
I'm just supporting my theroy. I know a pc will run over rammed.... mine does!
Heres a webcam shot of both 128mb ram installed. Tight squeeze with a flashlight and a webcam.
Herez my system info (start, program files, accesories,system tools, system information)
webcam shot of sys info so you dont think screencapture was edited.
I rest my case. just the fact of it saying 127mb ram on sys info should be proof enough.
How can you get two chips to add to an odd number, when they only make chips even numbered? ie: 32mb 64mb 128mb and 256mb...... just doesnt add up...
now mabey if you try to put a 256mb chip in a 128mb max system yea it might not boot up, but i know for a fact you can run an over rammed system. as i just proved and it does cause erratic stalling and freezing.
This was all in support of my post, i dont want people to read what 68 said and think i am giving out bs info because im not.
All pics were taken with pc on running webcam
good thing i didnt electrify myself.
dude...
If you've got 2 128mb sdram dimms in there and it's only seeing one, then the other one is either incompatible, dead, dead socket, or you got 2, 64's in there.
Whats the chipset?
Who makes the board?
Is it DDR, or SDRAM?
I bet if you remove one chip it will say 64mbs.
Now why do you have a meg missing you ask? Well back in the day PCs never imagined using anymore than 640K of ram, why you ask? hell if I know. Anyway, either 512K or 640K will always be put aside when it posts. This could also be the fault of having the bios reserve some ram for devices, settings, etc. But if you have 128mb's, most bios's will post 127mbs. If you ever go into a dos prompt and run mem, you will always notice it saing 640K base memory, the rest is extended/expanded.
Microsoft(R) Windows 98
(C)Copyright Microsoft Corp 1981-1999.
C:\Windows>mem
Memory Type Total Used Free
Conventional 640K 39K 601K
Upper 0K 0K 0K
Reserved 0K 0K 0K
Extended (XMS) 65,472K ? 523,080K
Total memory 66,112K ? 523,681K
Total under 1 MB 640K 39K 601K
Total Expanded (EMS) 64M (67,108,864 bytes)
Free Expanded (EMS) 16M (16,777,216 bytes)
Largest executable program size 601K (614,912 bytes)
Largest free upper memory block 0K (0 bytes)
MS-DOS is resident in the high memory area.
C:\Windows>
