Hi all!
I am going to rebuild my Chevy 350 and I need some advice.
Hope you can help me!
What do I have and/or want to re-use:
1) Stock Chevy 350 (4-bolt, 010 020 high nickel) from 1972. It's at the machine shop now to bore and hone (.020 or .030).
2) Stock crankshaft. Is polished and in good condition.
3) Standard piston rods. In good condtion.
4) Double hump (Mickey Mouse) 64cc heads, stock springs, rockers.
5) Edelbrock 2101 intake
What do I (not) want with the engine:
5) More power (torque) than stock; Need not to be >300HP.
6) No high rpm (<5500)
Some thoughts:
7) I live in The Netherlands, so what I buy in the USA, is at least times 2 (or 3) due to shippin, tax and import rates. Therefor I do not want to buy eg. forged pistons, Edelbrock camshaft etc.
8) It's a 'hobby' car, I have a decent car. I can spend money on it, but reasonable... no, no, the misses is not complainig
9) I drive on natural gas / LPG (not sure how it's called in the USA), with a Impco 425 (gas) carburator. High octane.
So... I have to buy:
10) A camshaft and lifters. I have a Edelbrock 2102 in my current block. It's okay, but maybe a little more torque. But idle must still be okay, rather no new springs, rather no new rockers, rather no new push rods. Please explain if it needs to be updated/changed. I know there are brands like Melling (ccs-2) and.... what is a good brand/replacement, please also give a partnumber?!
11) Pistons and rings. I was looking around and found some decent prised (Ebay, Summit) brands eg. Speed pro, Enginetech. I have no experience with pistons. The 'old' pistons had valve reliefs. What do I need (no dome please)? Flat Top, w valve reliefs? The size will probably be .020 or .030 over size. I guess Moly rings?
12) Timing set. Prefereably a double roller; have this on my current engine also.
13) Gasket set, full engine. Which gasket set? FelPro? What kind of head gasket -> thin steel or the blue ones with the steel rings? I have NO clue what deck heigh means or should be calculated, I do read a lot, but I don't understand (also I'm not native English speaker...).
14) HEI ignition.
15) Main bearings and piston rod bearing.
Hope you can give me some good advice on which parts to buy!
Best regards,
Rudy
Some thoughts:
14) HEI ignition.
Best regards,
Rudy
