need advise on testing msd btm with pump
Im going to the track this weekend for the first time and running only 5# of boost on the 427bbc with 8-71. Here at home i cant get enough boost into the btm to show me that it works like it should when i got #5 pounds at wot. I can only get #2 of boost on the gauge. @4000. I have the knob all the way to 3 degrees removed and starting at 0 pounds of boost. I have my timing at 38. I see no retard when i rev it up past 3500 with the timing light.. so im planning on buying a handheld vacuum pump from autozone and testing the btm. So any advise on using the pump? Rpms? how much vacuum on pump equals 5# of boost.
Discussion Starter #2 (Edited)
Okay thxz, so it has to say pressure pump. Do you agree that timng should not be coming out until 2# of boost starts? Im planning on mixing 50/50 91 octane and 110 race.
Discussion Starter #3
Tested the btm today with the air compressor set atat 5psi. Moved the btm knob from 0 to 3 and watched with the timing light the timing go down just like its simulating boost. So from what iv read in threads im going to set btm to start taking out timing at 1-2 lbs of boost and going to take out 2 degrees of timing per lb of boost. car ran 12.1 with no 8-71 so im hoping for a low 11 to high 10's with 5lbs of boost. Going to make some passes at 5000rpm shifts and make sure everthing is staying together
Discussion Starter #4
Ran the car at the track and and video taped the boost and tach. Didn't get 5lbs of boost until around 6000rpms. Then ran into more problems with rams raising way to quick and not going down when I shift. If my converter is flashing to high would it still let the tires come off the ground. So I'm going to change my gears from 4.88 to 4.10s see if that helps before I spend a bunch on a Hughes converter.
