1 - 2 of 2 Posts
bring the engine up to TDC ither by hand or bumping the starter.. you'll see the valves on cyl 1 close 1 at a time. when the second valve closes. turn the adjuster nut on the rocker to adjust it. you'll need a .016 feeler gauge.. adjust the valves to .016 clearance.. rotate to the next cylinder and do the same thing, and just keep doing that till you got all 6cyl's adjusted
1 - 2 of 2 Posts
