Just bought a powerglide trans. Currently running 200-4r transmission on my grand national.
What all do I need to convert over to glide? Just the BOP adapter plate? how will that effect spacing on the converter? Are the output splines for the drive shaft the same? The glide has a standard turbo input shaft. so I assume I can use any turbo series converter. Will the flywheel converter bolt holes line up?
Thanks in advance...
