Where there is a will, there is a way....
Last year I broke one in my wifes car,( 91 acura) and took an easyout to the remains.
The easy out wouldn't grab it so I wound up using a left handed drill bit on it.
That only drilled it bigger so I wound up drilling out the remains of the plug and chasing the threads with a tap.
I got some of the plug parts and chips down in the chamber and spent some time fishing it out with a magnet.
The biggest piece was 2 threads worth of the very end of the plug that wound it's way down into the cylinder when I was drilling with the big drill bit. I guess the drill caught on the ground electrode and screwed that peice right on in.
I could not pull it out with a magnet or a hook made out of welding rod.
It was too big to go back through the hole.
I am stubborn and determined to NOT pull the head. :spank:
I ground a chisel end on a long drift punch and reached in through the spark plug hole and chisel cut the piece in half on top of the piston while it was still in the chamber. Then I fished out the now smaller pieces with the magnet. I made sure that there was nothing else in the cylinder.
I won!
I spent an inordinate amount of time winning, but now that stupid car knows just who is boss
Yes it still runs.
Later, mikey
