i have a 1969 chevy stepside and i need help to get a handle on how iam to start this kind of progect if it is really what i should try to do with me and a couple of friends. i would like to see if you folks now of any good books or ect. on this thank you very much. :thumbup:
Tazz
Why? What are you doing to the rear end that you need to tub this PU? Exactly what changes are you going to make? Do you have an idea of a certain wheel/tire setup you want to try and run?
Tazz
Rat Rods Rule!
Discussion Starter #3
tubbing chevy
will, this is what iam puting in it. a jegs crate motor this motor has 450 hp . so don't believe the tire set up will do. it has a 12 bolt rear end in it with 411 gear but it limit slip . fist thing i need to change is rear end i believe? to posi . i really like the idea of tubbing it. it will be lowwerd also. oh yes the tranny is getting changed as well. as 4 what tire & rim to use what ideas do you have? thanks, rlj chevy ps. tranny is auto w\3500rpm stall.
