Unfortunately I don't have any knowledge of basic engine wiring, but I have an '82 Trans Am with some problems. To begin with, the alternator isn't hooked up (never was), the key switch is tore out (but turns over with a pair of pliers), and there's a wire cut under the hood that cranks the engine over when is reconnected. If I could find a basic diagram of how the distributer, starter, alternator and battery are connected I could probably get this straighted out. But at this point I'm in way over my head.
Thanks
Rex
Banned
the basic charging and starting wiring is pretty simple on all these gm vehicles and are the same color wires since way back when also on the trucks same.
purple thicker wire is the solenoid wire from the key switch
any red thicker wires go straight to a battery source
dark green small wire is temp sensor in cylinder head driver side
HEI is pink wire and thicker like the purple solenoid one
alternator is very simple
just make the charging post on it and the thicker spade connector wire on it hot all the time and it will work
can loop from the post up to the spade if you want
i have an 82 trans am too and have owned many of these cars i will be keeping mine forever, have too much into it and it is bone stock correct original other than the th350 and 2400 stall converter i swapped to, from the original 200c trans
once you learn the basic engine wiring under one 60s 70s 80s gm car or truck then you can do any of them
the only real change since long ago was in '73 and in '75 for internally regulated alternator, and for HEI distributor away from old points style
good luck
