I have a year old Rochester Q-jet stage 2 http://www.jetchip.com/Shop/shopdisplayproducts.asp?sppp=10&catID=36 it was running fine. I took the distributor out set the engine to TDC and reset the distributor. (Car ran fine) I tightened all the vacuum hoses and put new hoses in for **** and giggles. I started it and the engine warmed up and started hunting and had a annoying shake to it. I recently pulled all the plugs out. Its kind a hard to put them in well and tight because of the headers so i have to use a wrench. Could plugs or wires cause this? I also found what seems to be a vacuum leak at the secondary throttle plate shaft. Im not sure if the was there before but when i strayed carb cleaner on it the engine smoothed out. I don't understand how all of the sudden this leak i found made the engine run so shaky and not a steady idle out of no where. I can wiggle the shaft up and down very slightly as well. If this leak normal? I called Jet and they said they never put seals in that shaft. there is only like a half a tooth pick of space available at most. Any one have any ideas how to fix my problem? Could oil in the distributor cap cause this? or dirty plugs, not the right side gap? Please help.
