Can't see the top front of the door and how flush it is with your fender but if it's in a tad you can loosen up the hinge to door bolts and push the door out a tad, which will suck in the lower back corner. Looks like your other option is to twist it, but that's last option, and not only would I look to push out the top front first, I'd also check out the fender to see if it needs to go out a tad. To determine that look at the cowl vent and how it lines up to the fender and also how the fender lines up to the back of your hood. If it does need it than you can loosen up the fender bolt up high behind your door and shim it, then pull out the door, which will then fix your issue on the lower bottom. Twisting it as I said is last resort but the fastest to do.
