1 - 9 of 9 Posts
Hey guys, I have a 1968 chevy with a 76 small block 400 board 20 over. I am running a Engine Pro CamShaft Valve Lift is Int.488 Exh. 509 with a .050 duration. As of right now I have Edelbrock 750. with an edelbrok intake. I am having problems with keeping my engine running when I put it in Drive. My RPMs are set at 1200 idle, but when I put it into drive it drops down past 300rms if not lower, and bogs down and dies. Should I drop my carb size any? Or does anyone have any other suggestions to try?
carb size is fine.
what is your static timing set at,,
Is this a new carb,,,,
Is the engine new,,, and anything else to work with?
Im not for sure what you mean on static timing, I set it TDC. Carb is old, just rebuilt motor and trying to get it running, its flooding out real bad! What other information would you need to help me.
when you set the timing with the vacuum hose disconnected,how many ºs did you advance the timing from zero?Was the carb working before? Do you have a quality ignition system? Is the camshaft long duration? Are you using headers?
NOTE: you may need new plugs
Low manifold vac. at idle from duration of cam. Improper carb setup. The throttle plates are open too far for idle circuit function.
Banned
No offense but it sounds like you know just enough to really screw things up. I would either find a good mechanic that will fix your mess, or drop in a stock 350 that is in good running condition.
If you do want to fix this yourself I'm guessing it will take a greenhorn like you the better part of a week and you may spend a grand by the time your done.
Best of luck, if you're still wanting to learn what to do google is your friend but just learning what to do can take a person a while. A mechanic may get it fixed for less than a grand out the door. But it soy rs like your ignition is way off, fuel pressure may be out of line, prob needs a higher stall with that cam, and only God knows what else.
1 - 9 of 9 Posts
