Is there detailed info on setting up four link with coil overs. I have everything level and plumb, but when every gets tightened down the frame will move to the left a half inch.
Philippines Cowboy
I'll assume you're using a kit with an "extra" piece of tubing that's diagonal (or "slonchwise," as someone from the Midwest might say) to the 4links, used to locate the axle assembly laterally. Now, half an inch isn't all that much and I suppose you could even learn to live with it, but, if you're determined to correct it, I'd look at lengthening or shortening, as necessary, that diagonal tube or moving its attachment point at one end.
Discussion Starter #4
Stupid me. Was using old tires and rims to set up the frame. One tire was a half inch shorter, that must be the reason your not to use different brand tires together. All systems are go.
