1 - 2 of 2 Posts
i have a 79 4x4 cheve luv pickup it has a 1.8 liter Isuzu's moter my problem is the timming chain went out and i replaced it so when i put the moter back in because i had to pull it out to change the timming chain so any way the wire for the alternator arked on the frame so i checked the fuse that went out i replaced it so when i went to start the moter there was nothing no lights no nothing like the batery was out of the rig is there a inline fuse that may be my problem i need all the help i can get i use this truck for work please help
Doc here, :pimp:
A You blew a fusible link..
This is located in the engine bay off the starter solenoid big bolt, on about a 10 gauge wire coming off there..It can also be on any single Terminal power buss near the battery. OR it may be directly off the battery cable at the battery..
just located it, inspect it for melting, and go to the parts house and get a replacement..
Doc :pimp:
1 - 2 of 2 Posts
