Hello guys I had to take out my distributor HEI today and get some new parts for it cause it had seen better days.
Engine is 350 sbc 9.5 to 1 compression Quickfuel 650 cfm race carb, edelbrock rpm performer air gap, Iron eagle 200 cc heads ported and gasket matched, Comp cams big mutha thumpr hydraullic roller cam 531/517 lift ( will be replacing soon with lunati voodoo 60112 cam ). Be for I did anything the distributor has given me a miss here and there and it seemed like it would mis a fire here and there but worked ok I never had any pinging with my vacuum hooked up or anything also I did not have any kick back when starting.
Ok I got a Mr Gasket advance curve kit for it. It had originally Heavy springs for the centrifugal weights. The weights on it where worn out etc so I put all the new advance weights that came with my kit and also I went with the lighest springs wich are black and start to give me mechanical advace at 500 rpm. It was set at estimated 12 degrees initial timing wise before I did all this. I marked where the distributor was set at before I took it out and put it back the same way. When I tried to start it the first time it kicked back like it had too much advance so I loosend it up and retarted it a little and still got some kick back but not as much.
I now have it slightly retarted more then where the old mark is and it still wants to kick back here and there but not as bad at first. After it was running it seemed the miss was worse then before and does not run quit as smooth as it did but I do know with the lighter springs and weights I am getting more time in more quickly as to before with the stock springs it would not be fully timed till 5000 rpm or more. So what should I do now to get things going good? I just ordered a new HEI Distributor from Skip White on ebay and it comes with a vacuum adjustible canister. I will be replacing my above roller cam with a Lunati Voodoo Hydraullic roller cam with 231/239 @ 50 with 535/550 lift.
I need some help so I can get this thing timed right and running good for the best power and streetability and clean burning mpg all in one. I know it won't do excellent mileage but I want to get the most this engine can make. I don't have a timing light to use and I don't know what kind the autoparts stores have and what to look for if renting one. I know a lot of you guys on here have excellent experience with HEI's. I want to be able to have around no more then 12-14 degrees initial for a total of 32-34 total and around 48-50 with vacuum advance. I don't want to have a bunch of kickback and have to hoop up more stuff to get this to work good.
I don't know how this all works a hundred percent and how vacuum works in relation to initial timing and advance. Hope someone can help me with some pointers.
Thank you guys appreciate it.
Eric
Eric
