I have a 305 vin h 4bbl quadra jet carb. Here is the question. It runs ok in park or nuetral but when you put it in gear it idles really bady. I have adjusted the idle screw and replaced the spark plugs, dist cap, rotor, and coil. What should I do next. I have also just replaced the fuel filter to make sure it wasn't that. It goes from 1.5 k to 800 rpm when put into gear and sounds like it is missing.
Would a leaking valve cover gasket do this?
Your inputs are greatly appreatiated, for I am not a true machanic I just like to pretend.
