Head casting numbers
3927186 heads originally came on:
1969 Z-28 302 (2.02's, guide plates, screwed studs)
1970 LT-1 350 (2.02's, guide plates, screwed studs)
1970-1975 350 (1.94's, NO guide plates or screwed studs)
These were mostly used on 1 and 2-ton 'fleet sales' trucks with motors designed for using propane. On some of thes heads, one of the accessory bolt holes is 7/16" thread instead of 3/8".
Also used on appx. 10,000 "CE" long blocks and complete engines.
The engines were either 327HiPo or LT1 350's. (possibly 302's)
(all these had 2.02's, guide plates and screw-in studs)
These are GOOD PERFORMING HEADS...
Highly valued by the 69-Z28 crowd, especially w/late 68 date.
Yenko and Baldwin's cars received these heads.
2.02 heads are easy to spot off the engine without measuring. Look on the combustion chamber side and you'll notice that the valves look like they're nearly touching each other.
On 1.94 heads the valves are about 1/8" apart.
*edit*
3927185 are the low performance 327 and 307 heads used 1969-1973
