The dwell at coil should be 26 degree at cranking speed and 29 degrees at idle. point gap on high step of dist, cam will be around .016 maybe .017. The positive side of the coil should see 12v during crank. Hope this helps. Colebigrobdog said:iv got ford falcon 170 1960 motor and need to know what the dwell setting is.has any body got an idea
so the point gap is 0.016 are 0.017 of a gap and that with the feller gauge,. and the dwell should be 26 to 29eloc431962 said:The dwell at coil should be 26 degree at cranking speed and 29 degrees at idle. point gap on high step of dist, cam will be around .016 maybe .017. The positive side of the coil should see 12v during crank. Hope this helps. Cole
Yea the points are really supossed to be at .25 per the manual just seems alittle wide to me but it will work at .25. So do the .25 first see how it does there. Colebigrobdog said:so the point gap is 0.016 are 0.017 of a gap and that with the feller gauge,. and the dwell should be 26 to 29
